Denso Alternators
https://slantsix.org/forum/viewtopic.php?t=28474
Author:  mopar_nocar [ Sat Apr 19, 2008 9:06 pm ]
Post subject:  Denso Alternators
I have been given a Denso alternator off a 2001 Dodge Ram P/U. 1 catch, the bearings are bad. It turns really hard. 2 questions:
1) Can this thing be wired into my 65 Cuda? If so, how?
2) Where can I find the bearings? It is the 117A version. I found bearings for the Diesel alternator, are they the same? Here they are:
http://www.genosgarage.com/prodinfo.asp ... _ARK_BOSCH
thanks for any help.
sb
Author:  SlantSixDan [ Sat Apr 19, 2008 9:39 pm ]
All parts are available to rebuild this alternator. Any good local auto electrical house can supply 'em. These alternators wire up exactly like a '70+ Chrysler-built alternator: Two field terminals, doesn't matter which one gets your '65's one field wire and which one gets grounded. One output terminal. Some bracket adaptation will be required (shave about 1/8" off the bottom bracket). You will definitely want to rework the current path between the alternator and battery. The elegant way to do this is with an active shunt .
Author:  mopar_nocar [ Sun Apr 20, 2008 7:09 am ]
Post subject:  thanks....
much appreciated, Dan.
sb
