It is currently Fri Jun 19, 2026 6:04 pm
PostPosted: Tue May 13, 2008 5:39 am
the wiper blades on my 62 valiant signet 200 are worn out. napa had a replacement for me a couple years ago, but not now. they want me to replace both entire wiper arms, and i would prefer to stay stock look. any suggestions where to shop for replacement blades?
cshunley
62 valiant
73 valiant
54 new yorker
cs hunley
PostPosted: Tue May 13, 2008 8:51 am
If all you need is the wiper refill (rubber wiper-and-spine insert that fits into the "claw" retainers on the blade attached to the arm) then the refill you need is an Anco N12R (narrow plastic spine) or 19-12 (metal spine). Either of these might require you to slightly squeeze/reshape your blade's claw retainers but should be usable without much effort; I'd start with the 19-12. I see 'em at RockAuto, and the Anco people confirm they're current products, so any Anco stockist ought to be able to furnish them. The old 12-12 refill was an exact fit, but it's no longer made.
