Driver door mirror
https://slantsix.org/forum/viewtopic.php?t=28478
Page 1 of 2
Author:  70valiant [ Sun Apr 20, 2008 7:01 am ]
Post subject:  Driver door mirror
Where should the driver door mirror be mounted?
The PO told me some one ripped his mirror off at one time and apparently when he had body work done they filled in the holes and painted them over. I would like to reinstall the mirror and need to know where I need to drill holes. Can anyone help me?
Author:  SlantSixDan [ Sun Apr 20, 2008 7:27 am ]
2-door cars get the sideview mirror ahead of the leading corner of the vent wing window.
4-door cars get the sideview mirror at the divider bar between the trailing edge of the vent wing and the leading edge of the main door glass.
Author:  emsvitil [ Sun Apr 20, 2008 11:49 am ]
What year is that?
I know with earlier years (mine's a 64) outside mirrors were optional.
Author:  SlantSixDan [ Sun Apr 20, 2008 12:04 pm ]
The car shown is a '66.
Sideview mirrors (and reversing lamps) were optional equipment until 1965.
Author:  66Dart [ Sun Apr 20, 2008 1:02 pm ]
Post subject:  66 Dart - Driver Side View Mirror
70Valiant -
Below are pictures where the side view mirror attaches on my 66 Dart.
66Dart
Author:  SlantSixDan [ Sun Apr 20, 2008 1:14 pm ]
Interesting installation of a mirror on a 2-door in the 4-door location.
Dealers didn't always follow Chrysler's directions for installing sideview mirrors (and sometimes didn't even bother using Chrysler parts; see this thread).
Author:  70valiant [ Sun Apr 20, 2008 1:36 pm ]
Thank you Gentle men you have been most helpful
Author:  70valiant [ Sat May 10, 2008 9:28 am ]
I have one more question. What hold this thing to the door, I know it is screws but is there any reinforcement inside or does the the sheet metal give all the support?
I had to drill out the metal that held the plate that tentions the ball inside the mirror because it just flopped around. I bent the plate then drilled and added screws to make it tight again, now I need to get a new mirror glass(it was gone already), screws and mount it on the door.
Author:  SlantSixDan [ Sat May 10, 2008 9:59 am ]
Sheetmetal support only, no backbrace.
Author:  70valiant [ Sat May 10, 2008 10:13 am ]
Thanks Dan.
Author:  Fratzog [ Sat May 10, 2008 10:26 am ]
Just seen this post, but I was removing a mirror today myself and had a stripped srew that I could only get by inside the doorpanel. You probably could have seen where the original holes were on the underside and somehow poked them back out with a scribe, granted if, its acessible enough to reach or see.
Author:  70valiant [ Sat May 10, 2008 2:46 pm ]
I really dont want to try and remove the door panel if it isnt an absolute must. The last thing I want to do is destroy a fine piece like this if I dont have to.
Author:  zooter86 [ Sun May 11, 2008 10:19 am ]
Post subject:  Re: 66 Dart - Driver Side View Mirror
so where exactly are they supposed to be on the 2 doors?
Please read up the thread for the answer to this question.
Author:  MichaelS [ Tue May 13, 2008 6:35 am ]
Was there a passenger side mirror available to match the remote adjusting drivers mirror in '74. My car has just the driver side and I would like a passenger side mirror also.
By the way, my mirror is mounted with the leading edge of the base evan with the post for the vent window.
Author:  SlantSixDan [ Tue May 13, 2008 8:36 am ]
Yes. Starting in '66, there was a manually-adjustable RH sideview mirror that matches the LH remote unit. Both the LH remote and the RH matching mirror are available as new reproductions.
Page 1 of 2 All times are UTC-07:00
