225 vs 318
https://slantsix.org/forum/viewtopic.php?t=28482
Author:  1974duster [ Sun Apr 20, 2008 12:08 pm ]
Post subject:  225 vs 318
which one is better ???
Author:  polara pat [ Sun Apr 20, 2008 12:39 pm ]
Um... what forum are we on?
Author:  ceej [ Sun Apr 20, 2008 12:44 pm ]
Better?
They are different, certainly.
I've had four 318's. They're good engines. They won't get the economy the six will deliver generally, but it's easier to get big power out of an eight for obvious reasons.
With proper care, any of the small blocks can travel into high miles. Not in high power form though. For towing the boat over the pass in a decked out conversion van, a V8 would be the right choice.
Is there a specific use you have in mind for the "Better" engine? Power? Longevity? Fuel Economy? Once you've defined what you want to do, it becomes easier to make the compromises necessary to accomplish the goal.
10 second quarter mile cars that get 50 mpg and lasts a million miles are not going to happen in my tax bracket. :lol:
CJ
Author:  Charrlie_S [ Sun Apr 20, 2008 12:46 pm ]
Post subject:  Re: 225 vs 318
For what? Which 318, "A" motor or "LA" motor? Which slant six? 170, 198 or 225?
Author:  1974duster [ Sun Apr 20, 2008 12:57 pm ]
yeah i want Fuel Economy and some power
Author:  ceej [ Sun Apr 20, 2008 1:43 pm ]
Stick with your 225. Your going to be looking at a lot of money to convert to a V8.
Read up on some of the modifications you can do. Keep it within reason, and you can do it for a fairly reasonable investment.
With care, you can get the car up into the 20-23 MPG range Hwy. Anything beyond that will take a lot of work. Think ROI. (Return on Investment.)
If you spend $5k to pick up another 2-4 MPG, how far do you have to drive it to break even? With your foot planted firmly in the go pedal, any economy increases are going to vanish.
Your general "Economy and Power" want, makes me think of a supersix conversion. Don't expect it to stay with a healthy V8 or late model rice grinder though.
A mild 4 bbl build will deliver pretty good economy, but the investment up front will be more $$. You have to decide how much power, and what you are willing to spend to do it. Bumping compression up a bit, and playing with the ignition curve will be necessary to get a decent power benefit in any case.
To move into real power requires pulling the engine out and doing some serious modifications.
To get 30+ MPG and have good performance, look at newer technologies. That isn't going to start with a classic car. I don't commute in my Valiant. I have a little bitty three cylinder thing for that purpose.
If you are limited to one car, then you have some choices to make.
CJ
