Rear end lube plug....?
https://slantsix.org/forum/viewtopic.php?t=28494
Page 1 of 1
Author:  polkat [ Sun Apr 20, 2008 9:33 pm ]
Post subject:  Rear end lube plug....?
Decided today to check the lube level in my 7-1/4" rear end, but the plug in the cover has a rather large 12 point hole of some kind in it. Never seen this before. All others I've seen have a square hole that you can put a 1/2" drive into. Is there a special tool for this, or will something else work?
Thanks!
________
Maryjane
Author:  Joshie225 [ Sun Apr 20, 2008 9:43 pm ]
Same 1/2" square tool, but a double square plug.
Author:  polkat [ Sun Apr 20, 2008 10:50 pm ]
I think a double square would have 8 points.....right? This one has 12, but I'll try the 1/2 drive.
________
Com?te
Author:  SlantSixDan [ Mon Apr 21, 2008 8:57 am ]
Either that or a piece of ½" bar stock from the hardware store.
Author:  Doc [ Mon Apr 21, 2008 12:30 pm ]
I guess that makes it a "triple square" socket head plug... it still takes the same 1/2 inch drive tool. :D
