It is currently Sat Nov 21, 2026 5:06 am
PostPosted: Sun Apr 20, 2008 9:49 pm
HI all.. im havin an odd problem with my 66 slant. when the engine warms up theres smoke that pours out from under the breather cap on the valve cover and even come out from underneath the pcv valve.. im wondering what could be causing this? it would seem like somethin clogged up but im not sure what it is. the pcv is new but it doesnt mean its working i suppose. and the breather is clean. any suggestions guys?
thanks
PostPosted: Sun Apr 20, 2008 10:43 pm
The pcv should be working if it rattles when you shake it.
PostPosted: Sun Apr 20, 2008 11:10 pm
ive heard different stories about the rattling of the pcv valve.. some people thing that if it rattles its good.. some say if it rattles that means its bad...others say it doesnt mean it still works just because it rattles... im not sure which is true but i can tell u that the previous pcv valve i had was bad and it still rattled. i just read a nice post from someone on here about the workings of the pcv system. and it seems this is a really bad situation since this smoke is pouring out the breather when its function is to take in air. i have no idea why its doin this so im hopin someone on here can clear this up. thanks for ur posts
PostPosted: Mon Apr 21, 2008 12:41 am
hello,
one thing that sometimes is overlooked,is the actual rocker cover itself. the baffles in a worn and sooty engine can become totally blocked and the path to the PCV valve is stopped up. obviously then,even if a new valve is installed,it will not work.
it involves removing the cover and phyically cleaning the cover and any crap that is inside these baffle areas. poke bits of wire etc thriugh to clean as much as you can - or better still put another CLEAN cover on in place.
check out the hose for perishing and a clear airway also.
regards,Rod :D
PostPosted: Mon Apr 21, 2008 12:59 am
If you have enough smoke (or blow by) to overwelm the pcv, you have some worn out rings. No PCV will fix that! If the rings are OK, check to see if the hose from the PCV is clogged or collapsed. Also check the nipple on the carb. where the line goes for blockage.
PostPosted: Mon Apr 21, 2008 5:03 am
Pull the PCV from the valve cover, and start the engine. See if there is vacumm at the end of the valve, If there is vacumm, the valve is working. If no vacuum it could be a bad valve, a plugged hose, or the passage in the carb being plugged up. If it is the carb, it might be neccessary to remove the carb, and use a drill bit by hand to clean the passage from both the bottom and the side of the carb (it makws a 90 degree turn). One other thing it could be, is the carb gasket not installed properly, and the hole in the carb being covered by the base gasket.
PostPosted: Mon Apr 21, 2008 8:56 am
I'm kind of baffled (ba-da-BING!) how we're all finding it so difficult to accurately describe the PCV system. Maybe there's a full moon...? Sunspots? Somebody secretly replaced our dilithium crystals with new Folger's crystals? :shock:
Charrlie_S' test of putting your thumb over the end of the hooked-up PCV valve with the engine idling is a good one. It tells us if vacuum is reaching the valve, but doesn't tell us if the valve's good or bad.
Shaking the valve with the engine off and hearing the rattle means the valve shuttle isn't stuck. It doesn't mean the valve's necessarily good (though it's a fairly decent indication), and it has never meant the valve's bad.
In this case, the likely causes are a clogged or blocked PCV valve, hose, and/or passage, or an engine with serious blowby problems.
PostPosted: Mon Apr 21, 2008 2:41 pm
Dan when you say a blocked "passage" what do you mean? I'm assuming there must be some kind of a vent from the block to the head where the gases can escape to go to the PCV valve. If this is the case and thats what you mean by "passage" where would these be located?
Thanks again everyone for your posts.
PostPosted: Mon Apr 21, 2008 2:48 pm
Turbocuda: This is not a teen chat room, and you are not charged money for each letter you type in a post on this forum, so please, the word is "your", not "ur". It's "you", not "u". I've edited your post so that it is in English! :shock: Please see here for more information on how to write your questions to get the best possible answers.
The PCV valve connects to an 11/32" diameter rubber hose which runs to a fitting on the carburetor. That fitting leads to a passage through the carburetor casting and down through a hole in the carb-to-manifold gasket, through another passage in the intake manifold, that directs the flow of crankcase gas into the intake manifold to be consumed in the cylinders. The valve, the hose, and all the passages must be free and clear, and the hose must be in good condition (not cracked, no holes, routed properly) if everything's to work correctly.
You will want to buy the books described in this post right away; they are the three most important tools for working on your own car.
PostPosted: Mon Apr 21, 2008 3:02 pm
Ok so what are some tell tale signs of it being blow by? Shouldn't there be oil on the spark plugs and things of that nature or am I off base here?
How does the gases from the crankcase come up through the head to go to the pcv valve?
PostPosted: Mon Apr 21, 2008 3:16 pm
Turbocuda, please go and order those three books linked above. Go do it right now. You'll love 'em. They are the equivalent of a candy store and all-you-can-eat gourmet buffet all rolled into one, to feed the hunger of your knowledge for how your car works and how to fix it.
Blowby is combustion gas that enters the crankcase past worn or stuck rings, holed pistons, sloppy valve guides, and/or a blown head gasket. Oil on the spark plugs would indicate oil going the other direction (up the sides of the pistons, down the valve stems). It's possible to have both excessive oil consumption (oil on the plugs and blue smoke from the tailpipe) and excessive blowby (smoke out of the breather) on the same engine. It's also possible to have one or the other by itself.
Even engines in basically good shape will have some blowby. The PCV system draws air through the crankcase (in through the breather, sweep through the crankcase, out through the PCV valve) to sweep the crankcase gases out of the crank and burn them in the engine. It keeps the inside of the engine cleaner and reduces smog-forming emissions.
 Post subject: I can't resist...
PostPosted: Mon Apr 21, 2008 3:24 pm
Aye cap't somebody swapped them out with decaffenated and it's done turned the bloody vulcan green!!!!
:roll:
PostPosted: Mon Apr 21, 2008 3:27 pm
"it life, Jim,but not as we know it."
PostPosted: Mon Apr 21, 2008 6:50 pm
Not to hijack a thread, but it's related. If your engine is running at idle and the PVC is rattling like crazy.....what causes that? I thought I had a really loose rocker-arm, until I pulled the PVC out of the valve cover.
Just wondering...
225 Cubic Inches of Iron-Head American Muscle
225 bored .040 /.100 off block, Schneider Cam 224@.050~ .480 lift - Stock valves, blended bowls, Offenhauser intake with 500 Edelbrock carb
PostPosted: Mon Apr 21, 2008 7:21 pm
I had the same problem with the cheap two-bit plastic PCV, It rattled and hissed at idle since new. Changed it out with an all-metal unit of better quality. Will cost about 5-6 bucks (2X the cost) but should last longer (easier to clean) and is perfectly silent at idle..
Users browsing this forum: Google [Bot] and 6 guests
