| A-body disk brakes from F-body parts?? https://slantsix.org/forum/viewtopic.php?t=2850 |
| Author: | Craig [ Thu Nov 08, 2001 11:55 am ] |
| Post subject: | A-body disk brakes from F-body parts?? |
Which if any of the disk brake parts from a Volaré / Aspen will fit late model Darts and Valiants? I think the rotor and caliper is the same. What about the spindles and caliper mounts? cfield@ll.net |
| Author: | DusterIdiot [ Thu Nov 08, 2001 12:07 pm ] |
| Post subject: | Re: A-body disk brakes from F-body parts?? |
: Which if any of the disk brake parts from a : Volaré / Aspen will fit late model Darts and : Valiants? I think the rotor and caliper is : the same. What about the spindles and : caliper mounts? You might check over at slantsix.com I had posted all the part numbers from the 1976 parts catalog on what can be used for a F to A body front disk brake swap... -D.Idiot res0aus2@verizon.net |
| Author: | goldduster [ Thu Nov 29, 2001 1:19 pm ] |
: You might check over at slantsix.com I had : posted all the part numbers from the 1976 : parts catalog on what can be used for a F to : A body front disk brake swap... : : -D.Idiot The Spindles are not the same, though these parts are INTERCHANGEABLE (that's the key word) with the 73-'76 A-body setup Caliper Adapters Calipers Rotors (Same) Wheel Bearings Seals Dust Cap The F-body spindles are 3/8" taller andw will change your suspension geomotry. goldduster318@yahoo.com |
| Author: | kesteb [ Fri Nov 30, 2001 8:00 am ] |
: The Spindles are not the same, though these : parts are INTERCHANGEABLE (that's the key : word) with the 73-'76 A-body setup Check out <A HREF="http://www.moparts.com">http://www.moparts.com</A> . They have a couple of very long threads on this topic. A lot of people checked in on this, including some heavy weight Mopar mag writers. Very interesting reading. klesteb@aol.com |
