timing set parts
https://slantsix.org/forum/viewtopic.php?t=28526
Page 1 of 1
Author:  oo3 [ Tue Apr 22, 2008 6:30 pm ]
Post subject:  timing set parts
due to lack of some parts locally available i will be ordering parts for a timing set change, maybe from rockauto - 1st i want to make sure i order all that is needed - yes i know the first thing i should have is a factory manual and i will, but do not have one in front of me right now - parts to order - timing set - fel pro gasket set with repair sleeve - oil pan gasket - so are there any other parts or seals needed ? - oo3
Author:  DusterIdiot [ Tue Apr 22, 2008 8:12 pm ]
Post subject:  Say what?
What repair sleeve do you need? (timing cover seal?)
If you need most of the gaskets, just get the Fel-Pro KS2103, it will have everything to regasket the whole engine...
Author:  66aCUDA [ Wed Apr 23, 2008 7:50 am ]
Yup dont waste your time just buy the KS set.
Frank
Author:  oo3 [ Wed Apr 23, 2008 8:01 am ]
i see a pic of that set but cant tell - does it contain the repair sleeve felpro 16200 that is in the tcs45255 set? oo3
Author:  Joshie225 [ Wed Apr 23, 2008 8:36 am ]
Most likely you'll have to buy the repair sleeve by itself which is easy to do. Pioneer has them.
