| does engine oil go bad? https://slantsix.org/forum/viewtopic.php?t=28527 |
Page 1 of 2 |
| Author: | MiDi [ Tue Apr 22, 2008 7:11 pm ] |
| Post subject: | does engine oil go bad? |
rember the oil cans before plastic bottles? .... i do! i was cleaning out my garage and i found 2 cases of vavoline can in perfect condition. no rust, dings or anything other than dust. can i use this oil in my engine? i'm kinda broke so if i coudl use it then i would be mega stoked. cause i run my slant wide (3600rpm and above on freeway or i point it in a direction and floor it untill i arrive) open a lot and because of this it goes thru oil. thanks! neil |
| Author: | DusterIdiot [ Tue Apr 22, 2008 8:22 pm ] |
| Post subject: | Detergent vs. non... |
Yes, and no... I have seen oil left in oil pans for a few years literally turn to jello... Engine oil has detergents in it that help scrub some of the 'grime' out of your engine and hopefully keep it suspended so it comes out during the oil change... if left too long the detergents in the oil can break down and become acidic (eating away at a few things while in contact with them)... if the cans say 'non-detergent' and it's still pourable, it's still oil (but might not last long in your engine (it's made formore 'industrial type machines' like press brakes, metal shears, etc...) So it might still be useable, if your engine uses a quart a week, I'd say go for it since it wouldn't be hurting a wornout engine... if your engine is in good shape...give it some good stuff so it doesn't wear out prematurely... talk to you soon, -D.Idiot |
| Author: | Joshie225 [ Tue Apr 22, 2008 9:03 pm ] |
I would like to know what API service grade is on the cans. I believe SE or better is what was originally called for. It may be stamped into the disptick. I would not use a non-detergent oil not because of a lack of detergents, but because of a lack of other beneficial additives like anti-wear and extreme pressure additives. |
| Author: | LUCKY13 [ Tue Apr 22, 2008 9:18 pm ] |
I would run it, if your ole girl is burning oil already its not going to make much diff anyway and chances are its not going to hurt anything anyway. Its probably not going to do our enviroment much good but when your broke you have to do what you have to do. They where making some good oil even when we still had cans instead of plastic and there is a good chance it may be better in ways than what you can get now. If your real lucky it was oil ment for Diesel engines, that would be some good stuff for a old engine. If its a real heavy or light weight you can always mix it with some you buy so you dont have to run it straight. Jess |
| Author: | MiDi [ Tue Apr 22, 2008 9:30 pm ] |
here it is: ![]() havlone by texico 10-40 there is atleast 2 cases of it prolly more and yes its pourable and looks brand new, i toped off my car with a quart this afternoon. ![]() mmmmm free oil |
| Author: | DusterIdiot [ Tue Apr 22, 2008 9:41 pm ] |
| Post subject: | Sheesh... |
I should have one of the spouts for those in my 'stash' in the garage... (never thought I'd see a time where I'd use one again...) Look at the back and see what the rating is on it like Josh said... -D.Idiot |
| Author: | emsvitil [ Tue Apr 22, 2008 9:45 pm ] |
I think it would still be good. As for the detergents, I can only see those going bad if the oil had some use inside an engine with water and acid buildup from use (even if the water is burned off with heat) |
| Author: | emsvitil [ Tue Apr 22, 2008 9:46 pm ] |
| Post subject: | Ebay |
Sell it on ebay as a collector item.......... |
| Author: | MiDi [ Tue Apr 22, 2008 10:03 pm ] |
Quote: Sell it on ebay as a collector item..........
| Author: | dank10fenny [ Tue Apr 22, 2008 10:18 pm ] |
or keep it as a collector item. damn thats awesome, and will only ripen with age, teehee |
| Author: | 6shotvanner [ Tue Apr 22, 2008 10:22 pm ] |
MiDi,yes go for it BUT,use like an ice pick on the bottom of the can to get the oil out,then sell the empty cans.Maybe pack the emptys away and sell them in the future.Dude there are guys out in collector land that love that stuff.Are they all metal cans or the paper ones with the metal tops an bottoms? Use the oil then put them on some paper towels and let them drip out the left overs for a few years,then sell them.Nice find |
| Author: | MiDi [ Tue Apr 22, 2008 10:33 pm ] |
these are can top/bottom and paper sides. i also have some hella old all metal cans of oil but they are rusty and i am not putting those in my car! |
| Author: | Red [ Wed Apr 23, 2008 7:47 am ] |
"I should have one of the spouts for those in my 'stash' in the garage..." Or open it with a "church key", if you're old enough to remember what THAT is. Didn't find any beer in pre-pulltop/poptop cans on the shelf next to the oil by any chance, did ya? |
| Author: | MiDi [ Wed Apr 23, 2008 8:32 am ] |
Quote: Didn't find any beer in pre-pulltop/poptop cans on the shelf next to the oil by any chance, did ya?
no i didn't if i did i would of kept it cause i collect all things beer.i'm using a church key, i always keep one on me. |
| Author: | SlantSixDan [ Wed Apr 23, 2008 9:43 am ] |
Old 10w40? Sell as a collector's item or take to a used-oil recycling place. It wouldn't have been a good choice for your engine even when it was brand new. |
| Page 1 of 2 | All times are UTC-08:00 |
