| Weird 170 https://slantsix.org/forum/viewtopic.php?t=28528 |
| Author: | heckshemi [ Tue Apr 22, 2008 7:59 pm ] |
| Post subject: | Weird 170 |
I decided to take apart the 170 that's been sitting on my garage floor for the past two years. Came out of my "61 Valiant. First strange thing I noticed was the pistons .100 below the deck. Then I get the crank out and this thing is heavy! OK I've got one of those large counterweight cranks. What were the engineers thinking when they designed this crank? Why would you need a crankshaft this massive for a 170 cu. in. engine with a 3.125" stroke. Is there some advantage to this? I mean this thing is almost as heavy as the block. I checked the deck height....I've got one of those mythical 170 raised blocks. Compression ratio checks in at a healthy 6.9 to 1. Is this a forklift engine or something? |
| Author: | Charrlie_S [ Wed Apr 23, 2008 5:09 am ] |
Are you positive it is a 170? I don't know about any factory pistons like that, but the aftermarket ( I think Badger) did list a "low compression" piston for the slant six, which had a higher pin location. I don't remember the difference in the location, and that catalog is buried. It is possible this engine was rebuilt during it's 40+ year lifetime. |
| Author: | heckshemi [ Wed Apr 23, 2008 10:31 am ] |
Charrlie, Its been rebuilt. It has .040" over pistons in it. I checked 'em and they're right at 1.75" comp. ht. The block is about 1/8" taller than my other 170. I'm going to mill .100" off the deck to get the compression up. |
| Author: | HyperValiant [ Wed Apr 23, 2008 6:40 pm ] |
HecksHemi, I had the same problem when I pulled the head on my freshly rebuilt 170 only the pistons were .030 over and .075 in the hole.As my engine had been freshly rebuilt I chose to mill a .125 off of the head to get 9.3 -1 compression ratio.The engine seems to run well with this c.r. and a Comp 264 cam. HyperValiant |
