It is currently Fri Nov 20, 2026 2:29 pm
 Post subject: timing set parts
PostPosted: Tue Apr 22, 2008 6:30 pm
due to lack of some parts locally available i will be ordering parts for a timing set change, maybe from rockauto - 1st i want to make sure i order all that is needed - yes i know the first thing i should have is a factory manual and i will, but do not have one in front of me right now - parts to order - timing set - fel pro gasket set with repair sleeve - oil pan gasket - so are there any other parts or seals needed ? - oo3
69 a100 225 tree3
 Post subject: Say what?
PostPosted: Tue Apr 22, 2008 8:12 pm
What repair sleeve do you need? (timing cover seal?)
If you need most of the gaskets, just get the Fel-Pro KS2103, it will have everything to regasket the whole engine...
PostPosted: Wed Apr 23, 2008 7:50 am
Yup dont waste your time just buy the KS set.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Apr 23, 2008 8:01 am
i see a pic of that set but cant tell - does it contain the repair sleeve felpro 16200 that is in the tcs45255 set? oo3
69 a100 225 tree3
PostPosted: Wed Apr 23, 2008 8:36 am
Most likely you'll have to buy the repair sleeve by itself which is easy to do. Pioneer has them.
Users browsing this forum: Ahrefs [Bot] and 5 guests
