It is currently Fri Nov 20, 2026 4:39 am
 Post subject: carter bbd jets
PostPosted: Wed Apr 23, 2008 8:52 pm
where can you find different jet sizes for the 2bbl carter bbd?
 Post subject: Move to Engine...
PostPosted: Wed Apr 23, 2008 9:02 pm
Since the Fuel Injection section is for the development of moving away from carburators to EFI/TBI , this post will need to be moved...
BBD jets/metering rods for 1974+ carburators can be gotten from other 1974+ BBD's and supposedly from Carter/Edelbrock AFB carburators/aftermarket sources... if you have an older 'non tin top' carb then other BBD's of the era are your only source as they are a bit different than the later versions...
FYI,
PostPosted: Wed Apr 23, 2008 11:23 pm
I believe I can get you either jet set if you know what you need. The rods may be a little harder but it seems there may be some of them available. I will have to check to be sure, one version may not be available but I was thinking I could get both.
Jess
PostPosted: Thu Apr 24, 2008 5:42 pm
thanks and sorry about the misplaced post i wasnt paying attention
Users browsing this forum: DuckDuckGo [Bot] and 7 guests
