| The hpak 'mock up'... *3 pics* https://slantsix.org/forum/viewtopic.php?t=28547 |
| Author: | DusterIdiot [ Wed Apr 23, 2008 8:42 pm ] |
| Post subject: | The hpak 'mock up'... *3 pics* |
Here's what Ceej and Midi got to see while they were here... While I have a little time, I decided to 'unshelf' my Dutra Dual Duals, and the EFI Hpak and 'mock' them up on a late block and 'massage' them so they are ready for install when 'everything' 'jives'... As always I had to grind the casting 'blocks' under deck on teh driver's side of the block to make everything 'sit right', and had to whittle a bit on the front dual and cylinder #2 on the manifold to get it to sit right, but it's a start.. next I have to carve on the Hpak intake to get the rest of the washers to install correctly... So far to go... but every little thing counts toward the big picture... -D.Idiot |
| Author: | bigtex [ Wed Apr 23, 2008 8:46 pm ] |
I must say that is looking very impressive. Keep up the good work. |
| Author: | Joshie225 [ Wed Apr 23, 2008 10:37 pm ] |
OK, what's the scoop on the aluminum trigger wheel? |
| Author: | LUCKY13 [ Wed Apr 23, 2008 11:16 pm ] |
How long is just the runners on that intake? Looking good, with EFI on that setup it should rock. Jess |
| Author: | CARS [ Thu Apr 24, 2008 6:57 am ] |
Great work. Way to get those parts off the shelf and on a block! (Must do the same one of these days) |
| Author: | DusterIdiot [ Thu Apr 24, 2008 7:07 am ] |
| Post subject: | Off the shelf parts... |
Quote: OK, what's the scoop on the aluminum trigger wheel?
I'm also mocking up the MSD-8255 trigger wheel, since it is compatible with the Holley system (and the MSD ignition box, and the MSD CD coil....) and I wanted to stick to parts that 'jive' and are readily available 'over the counter'...-D.Idiot |
| Author: | wvenable [ Thu Apr 24, 2008 11:49 am ] |
Thanks for the pics! Very cool! |
