| carter bbd jets https://slantsix.org/forum/viewtopic.php?t=28549 |
| Author: | dclxvi [ Wed Apr 23, 2008 8:52 pm ] |
| Post subject: | carter bbd jets |
where can you find different jet sizes for the 2bbl carter bbd? |
| Author: | DusterIdiot [ Wed Apr 23, 2008 9:02 pm ] |
| Post subject: | Move to Engine... |
Since the Fuel Injection section is for the development of moving away from carburators to EFI/TBI , this post will need to be moved... BBD jets/metering rods for 1974+ carburators can be gotten from other 1974+ BBD's and supposedly from Carter/Edelbrock AFB carburators/aftermarket sources... if you have an older 'non tin top' carb then other BBD's of the era are your only source as they are a bit different than the later versions... FYI, -D.Idiot |
| Author: | LUCKY13 [ Wed Apr 23, 2008 11:23 pm ] |
I believe I can get you either jet set if you know what you need. The rods may be a little harder but it seems there may be some of them available. I will have to check to be sure, one version may not be available but I was thinking I could get both. Jess |
| Author: | dclxvi [ Thu Apr 24, 2008 5:42 pm ] |
thanks and sorry about the misplaced post i wasnt paying attention |
