It is currently Fri Nov 20, 2026 9:17 am
PostPosted: Thu Apr 24, 2008 7:08 am
ok so i bought a 65 dart and it origianally had a v8\
Im throwing a slant six in it now.
I got a slant six that was rebuilt 10,000 miles ago and has been sitting covered for about 4-5 years though,
So im going to do the usual pull spark plugs,put marvels in to free rings, turn it a few times,
i getting a 65 trans with all the linkage and converter.
so motor and trans is good then ill figure out my mounts and get my radiator hoses...lines ect. Then fix my brakes.register it and then Done?!
PostPosted: Thu Apr 24, 2008 7:32 am
You will need a 66 or older oil pan and pickup, and the 63-66 engine brackets and insulaters. If the engine has a 68 or later crankshaft, you will need a adapter bushing in the end of the crank, for the early converter.
