Oil pressure and Idle speed
https://slantsix.org/forum/viewtopic.php?t=28556
Author:  MichaelS [ Thu Apr 24, 2008 6:26 am ]
Post subject:  Oil pressure and Idle speed
Just got my Dart back from the shop were they supposedly rebuilt the carb, plus some other stuff, (because i was to lazy to do it myself).
The idle speed was set way to high so I lowered it to a point were it seems nice to the ear, no real test equipment here. Now when I stop and it idles the oil pressure light comes on, if I give it a little gas it goes off. Is this normal because I have it set to slow? Or is there somthing wrong with the oil system. The engine has 70,000 miles on it with no major work done to it.
Author:  Doc [ Thu Apr 24, 2008 9:10 am ]
Add a mechanical oil pressure gauge to see what the actual pressure is, in psi.
What weight oil is in the crankcase? You may want to use a thicker oil.
Try changing the oil pressure light sending unit.
A sticking oil pressure relief valve in the oil pump can cause this problem, you can pull and clean the valve from under the vehicle.
If nothing above helps, the low oil pressure condition is most likely caused by excessive clearance in the engine bearings or in the oil pump impeller assembly. The next step would be to replace the oil pump.
Author:  MichaelS [ Thu Apr 24, 2008 11:23 am ]
I have turned up the idle speed 1 turn of the screw. It is still an acceptable slow idle, no clunk into gear(automatic), and now the pressure light stays off. Thanks for the tips, I'm sure it is probably one of them.
