| New 5-leaf Springs https://slantsix.org/forum/viewtopic.php?t=28560 |
Page 1 of 2 |
| Author: | Pat Dawson [ Thu Apr 24, 2008 10:34 am ] |
| Post subject: | New 5-leaf Springs |
I ordered new 5-leaf springs from "springsnthings" (ESPO) as well as u-bolts and shackles. My original springs are 4-leaf but they don't make those and they say the 5-leaf will fit. I'm getting them because I'm holding the rear of the car up now with air shocks and I know that isn't a permanent solution. I haven't done this job before but it certainly looks do-able. Is there anything I should be aware or beware of? Thanks in advance. |
| Author: | Slanted Opinion [ Thu Apr 24, 2008 10:39 am ] |
Be prepared to enjoy your new springs! Other than that... this is a relatively easy job, no hassles. -Mac |
| Author: | vynn3 [ Thu Apr 24, 2008 1:24 pm ] |
| Post subject: | Re: New 5-leaf Springs |
Quote: Is there anything I should be aware or beware of? Thanks in advance.
I'd spray the various bolts with PB Blaster, Kroil, or some other good penetrant a day or so before you swap springs (maybe BOTH days). For me, the nuts on the U-Bolts were a PAIN. Only later did I think of cutting the ends off first... |
| Author: | volaredon [ Thu Apr 24, 2008 2:57 pm ] |
Pfft.... why waste the time even trying to get the U bolt nuts off.... they come off easier with a torch! Replace em, they are not that expensive. Especially whn you gotta fight em laying under the car; if I had a lift I might try to unscrew them. When I had the springs rearched on my Fury new bolts, nuts washers, etc were only $20-25. Not worth the hassle when they will either snap or the threads will peel about 80% of the time if they are the originals that the car left the factory with. |
| Author: | Sam Powell [ Thu Apr 24, 2008 7:14 pm ] |
You've got new u bolts coming anyway. Don;t throw the old springs away just yet. my new ones settled odwn very fast, and I combined one of the old leafs to create a six pack set, which brought the car back up. I don't know why the new ones failed to stay high, but the failure took place between the end of the number two leaf and the shackle. I really doubt if you will have problems, but just in case. Do you have a hydraulic jack? Jack up the body, put it on jack stands, and then support the rear with the a second set of jack stands while you take the bolts out of everything. Be sure to block the front wheels so they cannot roll, even though the rear of the car is on jack stands. It is not a difficult job. Make sure you do not stress your brake lines while the springs are unhooked. A big breaker bar makes this job much easier. Sam |
| Author: | vynn3 [ Fri Apr 25, 2008 6:33 am ] |
Quote: Pfft.... why waste the time even trying to get the U bolt nuts off.... they come off easier with a torch! Replace em, they are not that expensive. Especially whn you gotta fight em laying under the car; if I had a lift I might try to unscrew them. When I had the springs rearched on my Fury new bolts, nuts washers, etc were only $20-25. Not worth the hassle when they will either snap or the threads will peel about 80% of the time if they are the originals that the car left the factory with.
All true, unless, like me, he doesn't HAVE a cutting torch. I had brand new replacement U-bolts, but still had to get the old ones off.
| Author: | tlrol [ Fri Apr 25, 2008 10:51 am ] |
| Post subject: | Springs and their removal |
Sawzall or 4" or 4-1/2" hand grinder with a metal cutoff wheel. Probably the cheapest would be a Harbor Freight grinder. Five seconds and some sparks and bye bye U-bolts. Wear eye protection of course. The post about keeping the old springs is a good one, I added a leaf in my D-150 and paid $80 for two beefy spring packs, if I had some old springs laying around I could have done this for zero $$ and then tried it out. Thought about hitting a junkyard for some springs and then came to my senses... The toughest part will be removing the springs from the car itself, you can't really saw at those bolts that attach the spring eyes to the car. On the other hand, they probably aren't all skanky like the U-bolt ones are. I recommend a monster pressure washing, followed by wire brushing of the parts that need to be removed--followed up by liberal application of your favorite penetrating oil(s). A couple of jacks, jack stands, pry bars, and sledge hammer might be useful. I have even used a come-along before. Usually the pesky part is to get the spring centering bolt lined up into the hole--hence the pry bar, sledge hammer, and come-along. I did this about a month ago and the hand sledge was the Blue Ribbon performer for me. Consider cleaning up your rear brakes (if they need it), etc while you are back there as well... Goes with out saying that re-using any bolts that have been on there is a bad idea, new bolts are cheap insurance... |
| Author: | dank10fenny [ Sat Apr 26, 2008 11:19 pm ] |
i think i just pulled the axle, and hacksawed most of it and chiseled the rest. i didnt have any cool tools, hehe |
| Author: | Rug_Trucker [ Sun Apr 27, 2008 6:18 am ] |
air tools are a wonderful thing. Are the ESPOs Mexican made? I was reading on Moparts that JC Whitney sell American steel leaf springs. IIRC ESPOs are famous for drooping after a short while. |
| Author: | Sam Powell [ Sun Apr 27, 2008 6:47 am ] |
My "new" springs (new awhile back) certainly drooped quickly. Maybe they were from Mexico, but I thought the guy who sold them to me, from an ad in Hemmings made them himself. I guess you never know for sure. It was because of the drooping that I addedthe second leaf. Idid this by taking the old top leaf, cutting the eyes off of both ends with a hack saw, and inserting it into the pack right under the top one. I made the new, added leaf, end at the rear half way between the shackle and the end of the original 2nd leaf. That perked it right up, and has held it there for 10 years or so. Sam |
| Author: | Pat Dawson [ Wed Apr 30, 2008 3:54 am ] |
Springs, shackles, and u-bolts delivered yesterday. Looks like a match. Can't find any markings as to where manufactured. Won't be able to get to this installation for a while but I'll report back when I do. |
| Author: | Sam Powell [ Wed Apr 30, 2008 9:04 pm ] |
Once again, that is one beautiful car. Do you want to trade? Sam |
| Author: | Pat Dawson [ Mon May 05, 2008 3:55 am ] |
Don't go there Sam. Turbo, EFI, 5 spd. - that is one rockin' car. The new leaf springs are installed. The old bolts were tough to remove but all but one bolt were removed without cutting. Everything fit nicely and the job was done with just good ole' Sears tools, jack stands, and a hydraulic jack. Did throw a rod on my old Craftsman 2-cylinder air compressor. I guess after 16 years of use, I'll just go get another one. The air shocks are at the minimum 25 psi and the car sits higher now than it did with the old springs and 60 psi on the shocks. Feels like it rides better too. |
| Author: | Aggressive Ted [ Thu Jun 12, 2008 8:02 pm ] |
I got a set of 5 leaf springs from ESPO and they were too light so I had them make me a 6th full length spring. That did the trick...... |
| Author: | MichaelS [ Sun Jun 15, 2008 7:47 am ] |
My Dart still has its 4 leaf set up on it, now that is soft. Let us know how you like the 5's I may upgrade too. |
| Page 1 of 2 | All times are UTC-07:00 |
