| Got the transductor can (vacuum can/pod) off a computer? https://slantsix.org/forum/viewtopic.php?t=28597 |
| Author: | Wizard [ Sat Apr 26, 2008 1:49 pm ] |
| Post subject: | Got the transductor can (vacuum can/pod) off a computer? |
Either from leanburn or spark control computer? Mine is leaking vacuum on my 2.2L. I'll try to operate on it to replace leaking diaphgram or extract good vacuum diaphgram and use it. Otherwise, computer get ditched for megasquirt to control spark initially. Cheers, Wizard |
| Author: | Wizard [ Sun Apr 27, 2008 11:59 am ] |
| Post subject: | Mine is leaking air that the reason for this part request. |
If you have a pulled leanburn computer or carb 2.2 computer, I need the transductor off it. Otherwise, I'll go megasquirt for spark initially if I don't get replies or suggested otherwise. Cheers, Wizard |
