It is currently Wed Nov 18, 2026 9:21 am
 Post subject: Intake bolt question
PostPosted: Wed Apr 23, 2008 2:47 pm
There are two bolts by the egr on the intake. What do they connect to? Into the exhaust manifold?
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Wed Apr 23, 2008 3:57 pm
is it a one or two barrel setup :?:
one
Ronnie
PostPosted: Wed Apr 23, 2008 5:59 pm
are you looking at the two bolts that run through the intake and the exhaust manifolds, if so you throttle cable and kick down rod bracket attachs the the treads on the bottom with 1/2in nuts/ 5/16 treads.
PostPosted: Wed Apr 23, 2008 6:05 pm
There was no nuts on it.
Ronnie
PostPosted: Thu Apr 24, 2008 3:29 pm
there should be if you attach the bracket that clamps your cable and holds you kick down rod :!:
PostPosted: Thu Apr 24, 2008 5:10 pm
I think my exhaust manifold lost the part where the bolts screw in. What can I do now?
Ronnie
PostPosted: Fri Apr 25, 2008 5:49 am
that is a hard fix if the two long bolt that hold the intake/exhaust together have not enough treads showing below the exhaust manifold to attach the cable/kickdown bracket. most bolts brake when you try to remove them and then you have to drill the exhaust manifold and repair the treads or over size the holes and replace with longer bolts and nuts.
PostPosted: Sat Apr 26, 2008 8:10 pm
Well I feel stupid now. My brother pointed out to me that the bolt broke. I thought it was just another bolt at the bottom. Well now I got to put it all back on the engine.
Ronnie
PostPosted: Sun Apr 27, 2008 8:56 am
your never stupid when you can find a problem and fix it :wink:
Users browsing this forum: Amazon [Bot], Bing [Bot] and 6 guests
