It is currently Mon Nov 16, 2026 8:13 pm
PostPosted: Wed Nov 14, 2007 10:20 pm
Do I need to buy a different ignition coil to convert to electronic ignition?
1970 dodge dart, contact point ignition.
PostPosted: Wed Nov 14, 2007 11:25 pm
Clickme.
PostPosted: Thu Nov 15, 2007 7:45 am
It's not a good idea to use the stock coil.
In addition to the linked thread, you may also want to read this one.
PostPosted: Thu Nov 15, 2007 10:26 am
how much better is switching to HEI as opposed to mopar EI. Which is cheaper and how much does HEI improve the cars performance?
PostPosted: Thu Nov 15, 2007 12:34 pm
Your questions about HEI vs. Mopar electronic are answered in detail in the thread I linked to (and the thread linked off of that thread). Please take a few moments to read the existing answers to your questions, and if you still have additional questions after that, then post them here.
 Post subject: HEI conversion
PostPosted: Thu Nov 15, 2007 6:19 pm
Ok, I will take the bait...... after reading the suggested threads many times over the past 12 months, how much does the GM HEI improve the cars performance over the Orange MOPAR ECU?
My NGK UR4 plugs run a nice light cinnamon and it rarely skips a beat at idle. Using the Chromes Blaster 2 coil, 8mm wires, BlueStreak cap and M0-3000 rotor. It is and animal off idle.
So why change?
Is it for emissions reasons?
fewer hydrocarbons?
better mileage?
or does it last longer?
easier on the components so they last longer?
Dan, please share the technical findings.
 Post subject: Re: HEI conversion
PostPosted: Thu Nov 15, 2007 6:44 pm
Including this one...?
fewer hydrocarbons?
better mileage?
The HEI readily supports larger plug gaps, which means better driveability and mileage with reduced emissions. Also no ballast resistor, which means a failure point is eliminated. It's not that the Mopar system is at all bad, it's that HEI is better.
Also, while good Chrysler-style ECUs can still be had from the likes of Standard/BlueStreak and Echlin, all of the Mopar/Chrysler-sourced ECUs (Orange, chrome, gold, black, whatever) have been junk for several years now. Finest "Most Favored Permanent Normal Trading Partner" Chinese quality. :roll:
PostPosted: Thu Nov 15, 2007 8:49 pm
Thanks for the info
PostPosted: Thu Nov 15, 2007 8:54 pm
do I need an MSD BLASTER 2 coil for my bone stock 225 pickup,or is a stock coil OK? THANKS.
PostPosted: Fri Nov 16, 2007 12:45 am
probably the msd blaster
 Post subject: HEI vs MOPAR ECU
PostPosted: Fri Nov 16, 2007 8:19 am
Dan,
Do they sell the orange and chrome versions? or just the stock version.
If they sell the performance versions, such as the chrome or orange ECU,
would you have part numbers for them?
Thanks,
 Post subject: summit racing
PostPosted: Fri Nov 16, 2007 9:04 am
Summit stocks the orange,chrome and gold mopar ecu's, http://store.summitracing.com/partdetai ... toview=sku
63 valiant v200 Wagon 9.5, Schneider cam, E.I. 22 mpg all day
PostPosted: Fri Nov 16, 2007 9:25 am
Orange/chrome/gold is a Mopar-brand-only deal, largely a scam (the "differences" in these modules are more or less confined to the colour of the housing and the price) and—again—they're none of them worth spending money on (from Summit or anyone else), because quality is unreliably poor.
If you are sticking with the Mopar-style system, the performance from a Standard BlueStreak LX-100 (5-pin) or LX-101 (4-pin) or Echlin equivalent is as good as you can get.
PostPosted: Fri Nov 16, 2007 9:41 am
Thanks for the American part numbers Dan.
I had purchased my Orange Box from Summit and was wondering about the quality. Everything is new under hood from the painting the engine bay with the new Concept Series bright yellow while the motor was out, down to most of the wiring harness, wiper motor, radiator, etc. and of course the new engine build.
If wanted to run a test between both the stock MOPAR System and the HEI conversion, what would be the best HEI module and part# to buy?
It seems that I could easily jumper around the ballast resistor and unplug the ECU and plug in the HEI for a few months to see if I can document the differences.
Thanks, :D
PostPosted: Fri Nov 16, 2007 11:16 am
fewer hydrocarbons?
better mileage?
I completely agree. With the tech. advances today the question isint really why? its more like why not? I have a few mopar boxes on the shelf and they are definatly not the same as the originals (same look & part# but different feel to the metal and I dont know why but the new ones feel a little lighter to me. Maby it is just me I duno)
Users browsing this forum: Ahrefs [Bot], Bing [Bot], DuckDuckGo [Bot] and 4 guests
