| engine is done pic. https://slantsix.org/forum/viewtopic.php?t=28613 |
Page 1 of 2 |
| Author: | oklahoma joe [ Sun Apr 27, 2008 8:16 am ] |
| Post subject: | engine is done pic. |
I completed my first slant six it has: 8.4 compression ratio .060 of the head 3.460 bore 198 crank and rods stock pistons with cast rings Stock cam bumped up to a true .44 intake lift at valve degreed and set 3 degrees retared stock valves with hardened exhast seats ported intake and exhast runners super six intake and exhast gasket mached to head Carter bbd from a v-8 pre emmissions stuff Stock timming chain All for a total of $275 machining, piston pressing, valve job and mill $280 Engine rebuild kit with piston and oil pump $40 Cam regrind $55 supplies (silicone, paint, ect.) _____ $650 give or take $20 Not bad for a fresh engine. Here are some before and after pictures http://i263.photobucket.com/albums/ii13 ... -07020.jpg http://i263.photobucket.com/albums/ii13 ... IM1978.jpg http://i263.photobucket.com/albums/ii13 ... IM1977.jpg http://i263.photobucket.com/albums/ii13 ... IM1973.jpg http://i263.photobucket.com/albums/ii13 ... IM1974.jpg |
| Author: | slantzilla [ Sun Apr 27, 2008 8:36 am ] |
Nice looking motor! I like that valve cover treatment. |
| Author: | Doctor Dodge [ Sun Apr 27, 2008 9:00 am ] |
Looks great! You may want to re-think that big steel fan, those "eat" a bit of power and make a bunch of noise. My car actual cooled better at freeway speeds with a smaller fan. DD |
| Author: | terrylittlejohn [ Sun Apr 27, 2008 9:00 am ] |
two tone valve cover looks cool, nice job, what is it going in? |
| Author: | 75plyduster [ Sun Apr 27, 2008 9:00 am ] |
| Author: | Dart270 [ Sun Apr 27, 2008 10:49 am ] |
Looks great! One thing - do you mean the cam is 3 deg retarded from the stock spec? Lou |
| Author: | DusterTeen08 [ Sun Apr 27, 2008 10:59 am ] |
very nice engine |
| Author: | oklahoma joe [ Sun Apr 27, 2008 11:47 am ] |
its going in a 64 barracuda with a 230 3 speed full syncro. its going to be a driver and fun car for my wife to take to local shows. Right now the body is rough but very little rust and I hope to get it painted and start assembly buy late september [/quote] |
| Author: | oklahoma joe [ Sun Apr 27, 2008 12:28 pm ] |
I split the overlap and retarded it three degrees from there to hopefully gain a litle higher end performance. I'm not sure being that it is a small overlap if it will make a bunch of diffrence. I'm just playing with what I have to make the best of it with out laying out the cash for a hi-porformance cam. I also may put automatic in it later if my wife gets tired of driving a stick. |
| Author: | 66cudavatch [ Sun Apr 27, 2008 5:14 pm ] |
Looks awesome! big fan of the valve cover. |
| Author: | polara pat [ Sun Apr 27, 2008 5:22 pm ] |
Nice work, I started my swap in my '64 today. It's inspiring to see it all come together. |
| Author: | oklahoma joe [ Sun Apr 27, 2008 5:32 pm ] |
Quote: Nice work, I started my swap in my '64 today. It's inspiring to see it all come together
It feels good to have it all together. But I can't put it in the car for awhile and hear it run. I am debating mounting it to the k member and making and wood frame to start it on the ground so I can break it in and set he valves when hot. But more importantly hear it run. |
| Author: | BMXICAN [ Sun Apr 27, 2008 6:07 pm ] |
Dude, that motor is F****** BEAUTIFUL. Great job. Great inspiration! |
| Author: | polara pat [ Sun Apr 27, 2008 6:11 pm ] |
Quote: Quote: Nice work, I started my swap in my '64 today. It's inspiring to see it all come together It feels good to have it all together. But I can't put it in the car for awhile and hear it run. I am debating mounting it to the k member and making and wood frame to start it on the ground so I can break it in and set he valves when hot. But more importantly hear it run. |
| Author: | ply/six [ Sun Apr 27, 2008 6:25 pm ] |
| Post subject: | nice job |
Just jumping in. Nice job, I'm thinking of painting my engine body color, and i think the valve cover idea will catch on. |
| Page 1 of 2 | All times are UTC-08:00 |
