It is currently Tue Nov 17, 2026 8:48 pm
 Post subject: Block-off question
PostPosted: Tue Apr 29, 2008 2:07 pm
On my '83 peanut head there is a port on the very back of the head, right behind the #6 exhaust port. Is this an exhaust or simply heat passage? and what do we do about blocking it off? There is a threaded 1/4" or 5/16 hole right beside it and the port itself is not threaded.
PostPosted: Tue Apr 29, 2008 2:42 pm
Sounds like the air injection port. The threaded hole held down the air injection tube. I would see if it's a common size hole and tap in a freeze plug if possible. Otherwise you can make a little metal tab to bolt down. If the head isn't on an engine you can drill and tap the hole for a plug.
PostPosted: Tue Apr 29, 2008 3:09 pm
See this post
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 8 guests
