| LCA interchangeability https://slantsix.org/forum/viewtopic.php?t=28632 |
| Author: | sethmcneil [ Mon Apr 28, 2008 2:06 am ] |
| Post subject: | LCA interchangeability |
when did the sway bar tabs move? I have seen them mounted in the middle of the lca, and way out by the knuckle and strut rod assemblies... on a more urgent topic: are the lower control arms the same on the A vs. B-bodies? ive got a chance to pull a set with swaybar tabs off of a 68 Coronet Super Bee. but the car is slated to be scrapped soon. should i spring for it? (They would be installed in a 73 scamp, BTW) thanks! |
| Author: | DusterIdiot [ Mon Apr 28, 2008 6:58 am ] |
| Post subject: | I don't think... |
Quote: when did the sway bar tabs move?
1967-1972 uses a sway bar that mounted under the K member, and 1973-1976 used a bar that went through the K-member-D.Idiot |
| Author: | 65 dartman [ Mon Apr 28, 2008 7:06 am ] |
| Post subject: | Re: LCA interchangeability |
Quote: when did the sway bar tabs move? I have seen them mounted in the middle of the lca, and way out by the knuckle and strut rod assemblies...
Sway bar tabs mounted in the middle were used from 65 or so through 72. 73-76 were out by the knuckle.. I looked in my parts book and it shows different part numbers for the A and B body LCAs. I'd still grab them anyway as B Body people are always looking for that kind of stuff (along with sway bars)
| Author: | dank10fenny [ Mon Apr 28, 2008 10:07 pm ] |
ive got an aftermarket sway bar, i think from pst... they have the end links attach to a bracket that is bolted through the shouck mount, kinda lame i say, anyways... any way to make one of these stock options work, i didnt know they had lca's wit sway bar tabs already on them.... |
