carter carbs
https://slantsix.org/forum/viewtopic.php?t=28644
Author:  Slantcer [ Mon Apr 28, 2008 6:34 pm ]
Post subject:  carter carbs
So, I will be putting a 2 bbl intake and carter carb on the /6, my question is, are all carter two barrells the same flange size? Or is there a bunch of different flange sizes? I thought about buying one off ebay but the guy says it only fits a 318, I thought a 2 bbl was a 2 bbl. Thanks in advance.
Author:  SlantSixDan [ Mon Apr 28, 2008 6:45 pm ]
There are two different flange sizes for the 2bbl carbs. The small one was used on 6-cylinders and small-block V8s. The big one was used on big-block V8s. A 318 carb will bolt onto a slant-6 intake, but there'll be choke linkage issues to work around.
Author:  Slantcer [ Mon Apr 28, 2008 7:04 pm ]
when you say work around, how much are we talking? Fabrication? anything specific?
Author:  dank10fenny [ Mon Apr 28, 2008 9:47 pm ]
if dan is nice he will post the link to the carter manuals. one of them in particlular gets into detail the differences betwenn the 318 and /6 version. the way they explain it seems to be that the 318 version is way ineficiant on a slant. but thats just me talkin outta my @55.
Author:  DusterIdiot [ Tue Apr 29, 2008 6:41 am ]
Post subject:  Pretty much out your wazoo...
No it'll work, but the choke linkage is meant for the 318's choke thermostat not the odd angle of the super six stat... so he'll have to either:
a) use a manual choke cable
b) find a super six carb and swap the part
c) make a workaround
Also some of the carbs have holes in the throttle plates and this may or may not affect the idle/etc... depending on the engine's build
Author:  SlantSixDan [ Tue Apr 29, 2008 7:30 am ]
Carter BBD operation and repair manual (pdf)
