| How do you tell what carrier 8 3/4 gears are from? https://slantsix.org/forum/viewtopic.php?t=28705 |
| Author: | Kidd [ Thu May 01, 2008 10:09 pm ] |
| Post subject: | How do you tell what carrier 8 3/4 gears are from? |
Title says most all....do you go by the numbers on the gears? I got a set of 3.91's, and dont have a clue as to what # carrier it came from .Thanks!! Andrew |
| Author: | Joshie225 [ Thu May 01, 2008 10:50 pm ] |
It's all in the pinion. http://www.moparts.org/Tech/Archive/axle/1.html |
| Author: | Kidd [ Fri May 02, 2008 6:49 am ] |
Tanks Josh.....Thats exactly wat I needed!! Will get the gears from the garage now, and compare!! Andrew |
