It is currently Mon Nov 16, 2026 11:02 am
 Post subject: 170 cam
PostPosted: Sat May 03, 2008 11:45 am
I'm building a 170 for a daily driver and can't decide on a cam. Compression ratio will 10.0 to 1 or more depending on cam. Larger valves and port work.
I've got a stock cam and a Erson 270. I think the Erson may be to much in a 170 with stock converter.
Would the Comp 264 be a better choice? I want a good idle, good low and midrange, but not done at 4500.
Franklin
'61 Valiant
PostPosted: Sat May 03, 2008 8:59 pm
Have Erson grind you a "special" RDP cam, 266 on the intake and 244 (254) on the exhaust. See this link for the detailed specs
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
