It is currently Sun Nov 15, 2026 6:55 am
 Post subject: valve cover torque
PostPosted: Mon May 05, 2008 9:14 am
What should the proper torque value be on valve cover bolts for a 225?
64 barracuda
64 valiant convertable
65 valiant sedan
65 signet
74 vw beetle convertable
79 E-250 4WD van
94 dodge dakota
PostPosted: Mon May 05, 2008 9:26 am
According to my FSM, 40 inch pounds should do it!
Nice to see another Marylander online :D
Cheers,
Chris E.
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Mon May 05, 2008 9:52 am
I never use a torque wrench on any of the sheetmetal "covers". Usually the cover gets bent and / or the gasket gets distorted when factory torque ratings are used. (rated to go on once and not leak)
You want just enough tigntness to get a seal and to keep the bolts from vibrating loose, so snug them down, then give the bolts another 1/4 to 1/2 turn, working from the center out.
Inspect for leaks and recheck tightness after a couple of days, If the bolts are loose or leaking, snug them down a little more.
Users browsing this forum: Google [Bot] and 11 guests
