| valve cover torque https://slantsix.org/forum/viewtopic.php?t=28769 |
| Author: | 64conv65hard [ Mon May 05, 2008 9:14 am ] |
| Post subject: | valve cover torque |
What should the proper torque value be on valve cover bolts for a 225? |
| Author: | ValiantOne [ Mon May 05, 2008 9:26 am ] |
According to my FSM, 40 inch pounds should do it! Nice to see another Marylander online Cheers, Chris E. |
| Author: | Doc [ Mon May 05, 2008 9:52 am ] |
I never use a torque wrench on any of the sheetmetal "covers". Usually the cover gets bent and / or the gasket gets distorted when factory torque ratings are used. (rated to go on once and not leak) You want just enough tigntness to get a seal and to keep the bolts from vibrating loose, so snug them down, then give the bolts another 1/4 to 1/2 turn, working from the center out. Inspect for leaks and recheck tightness after a couple of days, If the bolts are loose or leaking, snug them down a little more. DD |
