Math Check
https://slantsix.org/forum/viewtopic.php?t=28791
Author:  61 V200 [ Tue May 06, 2008 2:20 pm ]
Post subject:  Math Check
7"dia balancer.
3.141592 (pi) X 7 = 21.9911.....
21.9911... / 360 = .0610....
.0610 X 10 = .610..... about ( not quite) 5/8"
So every 10 degrees advance/retard would be about (not quite) 5/8" around the circumference of the balancer.
True? False?
Author:  Joshie225 [ Tue May 06, 2008 2:44 pm ]
Looks good to me!
Author:  emsvitil [ Tue May 06, 2008 4:24 pm ]
The difference between .61 and .625 will add up.......
at 40 degrees you're 1 degree off.
By the time you go all the away around you're 9 degrees off, or just about 1 10 degree increment....
