Dutra Dual exhaust
https://slantsix.org/forum/viewtopic.php?t=28792
Page 1 of 1
Author:  ndevlin [ Tue May 06, 2008 2:22 pm ]
Post subject:  Dutra Dual exhaust
Who do I contact to purchase Dutra Dual exhausts for my 65 Dart?
Thanks
Author:  DusterIdiot [ Tue May 06, 2008 2:39 pm ]
Post subject:  Hang on...
Doctor Dodge or Doc (Doug Dutra) should pop up here and send you a PM with all the information...
It's worth the money!
[/quote]
Author:  ndevlin [ Wed May 07, 2008 4:43 pm ]
Thanks
Are the duals a pain to install ?
Author:  Fratzog [ Wed May 07, 2008 7:54 pm ]
Notso much as getting the original manifold off I would assume. Probably not to early to start squirting some penetrant on those puppies now and again to work in good instead of waiting till you have the new Dutras ready to install but end up spending an extra day or two extracting/replacing broken studs.
Author:  Doc [ Thu May 08, 2008 11:10 am ]
I have Dutra manifolds available so drop me a PM.
As already noted, the dual cast iron manifolds install the same way the factory manifold installs. The only additional work is adding a new exhaust pipe(s).
