It is currently Sun Nov 15, 2026 2:11 pm
 Post subject: Math Check
PostPosted: Tue May 06, 2008 2:20 pm
7"dia balancer.
3.141592 (pi) X 7 = 21.9911.....
21.9911... / 360 = .0610....
.0610 X 10 = .610..... about ( not quite) 5/8"
So every 10 degrees advance/retard would be about (not quite) 5/8" around the circumference of the balancer.
True? False?
Super Six Conversion Stromberg
PostPosted: Tue May 06, 2008 2:44 pm
Looks good to me!
PostPosted: Tue May 06, 2008 4:24 pm
The difference between .61 and .625 will add up.......
at 40 degrees you're 1 degree off.
By the time you go all the away around you're 9 degrees off, or just about 1 10 degree increment....
