Weber Carb Question
https://slantsix.org/forum/viewtopic.php?t=28795
Page 1 of 1
Author:  Wesola78 [ Tue May 06, 2008 3:59 pm ]
Post subject:  Weber Carb Question
I currently have the ProLine Fuel/Offy dual carb with Webers on my Volare. I've been thinking of switching back to one carb for simplicity, as well as economy. However, I wouldn't mind rejetting/tweaking these two carbs if that's possible.
I can barely see the numbers on the carbs; the first digits look like "36", and then "DNVO", or "DVNO".
I'm gonna check out some websites to see if I can figure out which Weber carbs I have.
Any suggestions on tuning or modifying these carbs will be appreciated.
Thanks!
Author:  Wizard [ Tue May 06, 2008 4:51 pm ]
click a picture or two of this carbs on your slant and post here?
Cheers, Wizard
Author:  Wesola78 [ Sat May 10, 2008 12:20 pm ]
Another member here who has this same setup identified these carbs as being Weber DCNVH36 carbs.
My slant is mostly stock, I wonder how it would run with using one of these carbs on an Offy 4bbl intake with an adapter plate? I may have to change jets though.
Any feedback is appreciated!:D
Author:  Slanted Opinion [ Sat May 10, 2008 2:33 pm ]
How about swapping to a pair of staged Webers? That way you can have 2 bbl economy and 4 bbl performance in the same package.
Setup is still a pain compared to a single carb, though.
-Mac
Author:  Wesola78 [ Sat May 10, 2008 9:31 pm ]
Yeah, I could probably get that to work, but I'm looking for simplicity in addition to economy.
