| Trans ?? https://slantsix.org/forum/viewtopic.php?t=2884 |
| Author: | Tom [ Mon Nov 19, 2001 5:29 pm ] |
| Post subject: | Trans ?? |
Are any of the "fast" slant 6 guys(11.50 or quicker) running a 727 trans? Are they all running 904's? ke4dgi@aol.com |
| Author: | Doctor Dodge (Doug Dutra) [ Mon Nov 19, 2001 7:24 pm ] |
| Post subject: | Re: 904 vs 727 RG Trans ?? |
: Are any of the "fast" slant 6 : guys(11.50 or quicker) running a 727 trans? : Are they all running 904's? I have always run 904's with all the V8 999 "inners" and never have a bit of trouble. I know of a few V8 racers who also run the 999, they say it make the car .2 quicker due to less weight and less mass to spin. DD |
| Author: | Tom [ Mon Nov 19, 2001 8:09 pm ] |
I have heard that too but about a year ago one of the Mopar mag did a article that swapped a 904 and 727 behind a small block. They basically said there was not the loss of ET that most people thought. Wish I had saved the article. I was just curious if the guys running 10's and low 11's were having trans problems out of 904's. ke4dgi@aol.com |
| Author: | Doctor Dodge (Doug Dutra) [ Mon Nov 19, 2001 8:21 pm ] |
| Post subject: | Re: 904 problems & breakage |
: I have heard that too but about a year ago one : of the Mopar mag did a article that swapped : a 904 and 727 behind a small block. They : basically said there was not the loss of ET : that most people thought. Wish I had saved : the article. I was just curious if the guys : running 10's and low 11's were having trans : problems out of 904's. All the SL6 racers I see running automatics are using the smaller 904. (one "Maverick" was running a powerglide but saw the light and switched back to the 904) As for the biggest problem we see, it is with busted front pumps and / or torque converter neck. (hub) DD |
