It is currently Fri Nov 27, 2026 12:59 pm
 Post subject: slant trans
PostPosted: Wed May 21, 2008 8:31 pm
ok so i have a slant six and i need a trans...
its going in a "65 dart" so i know i need it to be 1965 or a few other years earlier will work 1964 63? or so.
As long as its cable operated.
i was also told push button trannies will work ie: 63-64 and so on.
i found one thats liek 62-62 what will work?
PostPosted: Thu May 22, 2008 4:38 am
The 65 transmission is a one year only deal. It is cable operated like the earlier ones but I blieve it has a single cable instead of 2. The earlier pushbutton trannies are not a direct bolt-in replacement for a 65.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu May 22, 2008 6:45 am
Actually, at least 63-65 trannies are essentially the same except for some minor valve body differences. All have 2 cables - one for park and one for shifting. The difference in '65 was the column shift instead of the pushbuttons. I would bet that 60-62 trannies would work too, but I'm no expert on those.
You might search the site to see what valve body diffs there may be. Pat Blais could likely sell you any minor parts needed. I have run 64 and 65 trannies in my 64 Dart with no trouble.
PostPosted: Thu May 22, 2008 4:41 pm
I stand (sit) corrected! That is contrary to what I had understood and am glad to know the straight scoop.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
