It is currently Tue Nov 17, 2026 4:06 am
 Post subject: Plug speckling
PostPosted: Mon May 12, 2008 3:21 pm
I pulled my plugs to check them out due to a sparatic miss on acceleration and found that the #5 plug has a gold/brass speckling on it. All the other plugs where clean, I pull my plugs frequently so this is definatly new. I am going to borrow a comp tester and test that. Any ideas as to where the brass colour stuff could originate from?
TF
Even in moderation i am excessive!
PostPosted: Mon May 12, 2008 3:26 pm
Are all the butterfly hold-down screws still in the carb? :shock:
PostPosted: Mon May 12, 2008 3:56 pm
Yea they are, even put a twist to them to be sure they were tight! All the air bleed inserts are in place too.
TF
