| Sun Distributor Machine and slant specs... https://slantsix.org/forum/viewtopic.php?t=28917 |
| Author: | DusterIdiot [ Mon May 12, 2008 9:10 pm ] |
| Post subject: | Sun Distributor Machine and slant specs... |
Well now I'm the proud owner of a sun distributor machine, it all works good (better get the number for the strobe bulb in case it ever burns out!) It has a nice selection of 'specs' for all sorts of 50/60's cars on the rolodex... So far: 60 Valiant 170 cyl, QX-1 Hyperpak, Dist # 2095550 Rotation right Dwell:36-42 degrees 'each' gap .017" or 48-54 degrees 'both' gap .023" gap Spring Tension 17-21.5 Automatic Advance: Vacc. None 425-575 rpm 0 deg. 575 0-6.5 deg. 800 5-7 deg. 3400 11.5-13.5 deg. I'll have to get the specs for the 60-61 170 and the 225 to compare... -D.Idiot |
| Author: | Charrlie_S [ Tue May 13, 2008 5:27 am ] |
Hey, DI. Any chance you got "documentation" with the machine? I got a "freebie" last year, but no paper work. I would like to have copies, if possible. |
| Author: | SlantSixDan [ Tue May 13, 2008 9:07 am ] |
| Post subject: | Re: Sun Distributor Machine and slant specs... |
Quote: Well now I'm the proud owner of a sun distributor machine, it all works good (better get the number for the strobe bulb in case it ever burns out!)
I'm totally envious. I want one of those, too!Quote: It has a nice selection of 'specs' for all sorts of 50/60's cars on the rolodex...
The next time I'm in Denver, I'll dig up my big file of '60s-'70s Chrysler distributor spec charts and send them to you.Quote: 60 Valiant 170 cyl, QX-1 Hyperpak, Dist # 2095550 Rotation right
"Each" and "Both", eh? Interesting — a dual-points distributor with no vacuum advance. Dwell:36-42 degrees 'each' gap .017" or 48-54 degrees 'both' Automatic Advance: Vacc. None 425-575 rpm 0 deg. 575 0-6.5 deg. 800 5-7 deg. 3400 11.5-13.5 deg. I am guessing that 2095 550 was probably a Prestolite-built ("Auto-Lite", at the time) distributor, since that's who supplied the dual-point distributors for Chrysler's big high-perf V8s. |
| Author: | DusterIdiot [ Thu May 15, 2008 6:50 pm ] |
| Post subject: | Sorry Charlie! |
I finally looked in the cabinet and it has some 'tools' for the machine, but no manual... I did find a manual for a late model version here. But you will need a good internet connection as the 21 page manual is in a 3.3 meg PDF... most of the information to 'using' the machine pertains to all models, but there are some 'feature' upgrades from version to version.... Sorry for the wait! -D.Idiot |
| Author: | Charrlie_S [ Fri May 16, 2008 4:59 am ] |
Thanks, I'll check it out. |
