It is currently Thu Nov 26, 2026 12:57 am
PostPosted: Sat May 10, 2008 6:03 pm
I'm putting a set of Cragar SS's on my Valiant, 14x6 in the front and 14x8 in the rear. Does anyone have any suggestion for a good tire size? It currently has the stock 13's so I don't really have anything to go off of.
Thanks.
64 Plymouth Valiant
PostPosted: Sat May 10, 2008 7:58 pm
195/70 F 235/60 R but I'm not sure on the 235 fitting in the rear.......
I think you'd be better of with 14x6 F/R with 205/70s
PostPosted: Mon May 12, 2008 7:20 am
I guess I'll have them check clearance with the 235's once they're mounted on the rim. I've already bought the rims and don't want to hunt down two more. Thanks for the tire suggestions.
64 Plymouth Valiant
PostPosted: Mon May 12, 2008 2:44 pm
rear-245/60, 245/50,265/50
front-195/70,195/60,205/60
im running 245/50 on 9" slots in rear and195/60 on 6" slots in front(i have huge rear wheelwelle though,61 lancer). you would prolly have to jack up the rear on a 64 valiant or cut out the wells if they r rusty..........ss
