It is currently Sat Jun 06, 2026 6:33 pm
PostPosted: Thu May 15, 2008 1:31 pm
Simple question, since the engine I just bought is a '66 and going into a '74 car: will the '74 engine's spool type mounts bolt right onto the '66 block?
PostPosted: Thu May 15, 2008 1:48 pm
Yes, the later engine mounts will bolt right onto the 66 block.
FYI, The 66 "small hub" crankshaft will not bolt-up to a 74 automatic transmission / torque converter.
PostPosted: Thu May 15, 2008 2:05 pm
No worries there. I'll be mating an A833OD to it (and will definitely make sure I get the right flywheel) :D
