It is currently Tue Nov 17, 2026 3:11 pm
 Post subject: Magnacore plug wires
PostPosted: Sat May 10, 2008 6:25 pm
Dan, You suggested Magnacore wires a while back, which size have you tried, I saw the 8.5mm for around $50.00 online, will they fit with the stock cap? I think its time to replace the old wires, they have been on there since Madona had baby fat.
Grandpa's 1974 Dart Custom 4 door 225 auto, Aluminum Radiator, 1920 Holley.
PostPosted: Sun May 11, 2008 4:15 pm
Any other good wire choices or suggestions ? Will be used with future HEI upgrade on '74 225,
Thanks
PostPosted: Sun May 11, 2008 4:47 pm
8.5mm is big overkill. Use one of the smaller-diameter Magnecor wire sets, and save yourself some cash.
PostPosted: Wed May 14, 2008 5:54 am
Would the 7mm Magnacores be fine for the HEI equiped slant 6?
PostPosted: Wed May 14, 2008 1:21 pm
They'd probably be fine, but I'd probably pick the middle option (8mm).
