Spool type mounts on older block
https://slantsix.org/forum/viewtopic.php?t=28958
Author:  Jopapa [ Thu May 15, 2008 1:31 pm ]
Post subject:  Spool type mounts on older block
Simple question, since the engine I just bought is a '66 and going into a '74 car: will the '74 engine's spool type mounts bolt right onto the '66 block?
Author:  Doc [ Thu May 15, 2008 1:48 pm ]
Yes, the later engine mounts will bolt right onto the 66 block.
FYI, The 66 "small hub" crankshaft will not bolt-up to a 74 automatic transmission / torque converter.
Author:  Jopapa [ Thu May 15, 2008 2:05 pm ]
No worries there. I'll be mating an A833OD to it (and will definitely make sure I get the right flywheel) :D
