| Spark plug spacers https://slantsix.org/forum/viewtopic.php?t=28961 |
| Author: | plymouthfan [ Thu May 15, 2008 4:21 pm ] |
| Post subject: | Spark plug spacers |
Sorry if this topic has been covered before.... I seem to remember reading somewhere the metal spacers on the spark plugs should be removed before installation on /6's, is this correct? Is cutting them off the best way to remove? Thanks guys! |
| Author: | SlantSixDan [ Thu May 15, 2008 4:27 pm ] |
Remove the metal ring washers when installing plugs in '63-'74 slant-6 cylinder heads. Leave them in place when installing plugs in '60-'62 slant-6 cylinder heads. Usually easiest to grasp the ring around its diameter with a pair of pliers and unscrew the plug out of the washer. |
| Author: | Sam Powell [ Thu May 15, 2008 4:36 pm ] |
Dan, regarding your new signature: As compared to what? Sam |
| Author: | SlantSixDan [ Thu May 15, 2008 4:43 pm ] |
I was wondering how long that would take! It was the slogan used to advertise the new 1960 Chrysler Valiant in (German-speaking) Switzerland and probably Germany as well. It means "Not a centimetre too long, not a kilogram too heavy!", i.e., just the right size car. Compare the American slogan for the same car in the same year: "Nobody's kid brother!" |
| Author: | plymouthfan [ Thu May 15, 2008 4:44 pm ] |
Thank you sir! |
| Author: | MichaelS [ Thu May 15, 2008 5:57 pm ] |
Just curious, why is the washer on the spark plug removed on the '63-'74 slant 6? |
| Author: | SlantSixDan [ Thu May 15, 2008 6:00 pm ] |
Please see here |
| Author: | Sam Powell [ Thu May 15, 2008 7:39 pm ] |
As compared to standard cars of the day. In other words, air craft carriers. I like the slogan. Good for you for finding that. Sam |
