| Duster Fuse panel Hookups https://slantsix.org/forum/viewtopic.php?t=28962 |
| Author: | clyderancid [ Fri May 16, 2008 4:14 am ] |
| Post subject: | Duster Fuse panel Hookups |
On a '74 Duster on the fuse panel, the #4 fuse and fuse contact bar were blown out when we got the car. I suspect this happened when a previous owner took out all the A/C stuff, but left the A/C heater panel and vacuum lines. My wiring diagram either doesn't tell me or I can't find what that fuse controls. The heater blower switch does not get current to it (I've got the whole heater panel out), so I suspect it's that fuse. But I lose track going thru the wiring diagram of just which wires are supposed to go to that fuse. I'm using the wiring diagram in a Haynes manual. If I know which the right wires are, I figure I can install a line fuse to replace the blown fuse connection. Does that sound like a plan? Or does anyone have a better idea? I'm open. The car REALLY gets fogged up w/o a blower when it rains out here in the NW. Thanks so much for your help. |
| Author: | wjajr [ Fri May 16, 2008 4:51 am ] |
(YGGFM) Yeah guttah get a factory manual. But for now look here for a diagarm: http://www.mymopar.com/wiringdiagrams.htm |
