| Engins swap https://slantsix.org/forum/viewtopic.php?t=29012 |
| Author: | john b [ Sun May 18, 2008 12:43 pm ] |
| Post subject: | Engins swap |
Engine swap I have a 73 Dart with a bad slant six with auto trans. Found a good deal on a slant six from a 85 d100 sitck trans truck. Will everything fit together including trans, flex plate from the dart, and are the motor mounts in the same place? |
| Author: | SlantSixDan [ Sun May 18, 2008 12:57 pm ] |
This will work without difficulty. You will need to use the oil pan and oil pickup tube from the Dart's engine. Use the Dart's engine mounts complete (including upper and lower brackets). |
