Kickdown linkage question
https://slantsix.org/forum/viewtopic.php?t=29020
Page 1 of 1
Author:  bigtex [ Sun May 18, 2008 8:42 pm ]
Post subject:  Kickdown linkage question
I just installed a Offy intake with a Holley on a 64 dart with a push button 904. I have not come up with a way to set up my kickdown, if I drive it like a manuel valve body will it hurt the trans???Thanks for the info.
Author:  SlantSixDan [ Sun May 18, 2008 10:33 pm ]
Manually shifting the automatic gets around the functional part of the problem but the trans will still be subject to accelerated wear until you put in a kickdown. How about this one?
Author:  bigtex [ Mon May 19, 2008 7:06 am ]
That kit looks good, a little on the pricey side but I guess if you factor in all the time i will have tring to do that myself its pretty justified. Thanks Dan, I hope to order that up shortly.
Author:  SlantSixDan [ Mon May 19, 2008 9:20 am ]
Well, the less-money/more-work version is here .
