Z-bar failure
https://slantsix.org/forum/viewtopic.php?t=29036
Author:  slantfin [ Mon May 19, 2008 2:09 pm ]
Post subject:  Z-bar failure
I pulled into the driveway and pushed in the clutch pedal which didn't come back up. I looked under the hood, and the z-bar had moved over toward the engine, coming off the body-mounted ball stud. I had recently rebuilt the z-bar with new bushings and seals, but didn't get a new clip which clips on the z-bar, replaced the old one. Did I do something wrong possibly? From time to time I make a mistake, I find. Has this happened to anyone, or does anyone have any insight they can share.
Author:  slantfin [ Mon May 19, 2008 4:50 pm ]
OK I took it apart, and plan to assemble it out of the car. It's a good car that dies in the driveway instead of on the road.
Author:  slantfin [ Mon May 26, 2008 5:50 pm ]
Post subject:  fixed for now
Somewhere between new /6, column 3 to floor 4, and a frame replacement from the door forward, the space between the ball studs grew 1/2 inch. I moved the one mounted to the frame over 1/2", should have moved the other one, it turned out. Still, with a few modifications, everything lines up better and the clip clicked in.
Thank you Veterans and active personnel, on Memorial Day.
