Super 6 Exhaust
https://slantsix.org/forum/viewtopic.php?t=29073
Author:  74/6 [ Wed May 21, 2008 2:50 pm ]
Post subject:  Super 6 Exhaust
I know the super 6 and the standard 6 share the same maifold. When putting on the 2.25 exhaust do you make an adaptor or will the flange for the larger pipe bolt to the manifold. Thank you Steve
Author:  ceej [ Wed May 21, 2008 3:20 pm ]
It bolts right up! :D
CJ
Author:  MichaelS [ Wed May 21, 2008 4:12 pm ]
What is the diameter of the manifold at the flange? 2.25?
Author:  Doc [ Wed May 21, 2008 4:16 pm ]
The outlet size on a factory SL6 exhaust manifold is 2 inch, sometimes a bit over. It is easy to open them up more with a die grinder.
