Increasing slant displacement
https://slantsix.org/forum/viewtopic.php?t=29084
Page 1 of 1
Author:  68barracuda [ Wed May 21, 2008 10:05 pm ]
Post subject:  Increasing slant displacement
Hi Guys,
I was wondering, with the exception of overboring the slant what can be done
to increase CID, and what will be needed?
Is there stroker kits available? heaven forbid an even longer stroke!! :shock:
Just curious and eyeing a truck block I traced down.
Fanie Gerber
Author:  Joshie225 [ Wed May 21, 2008 10:27 pm ]
http://www.slantsix.org/articles/stroking/stroking.htm
Author:  runvs_826 [ Wed May 21, 2008 11:33 pm ]
Search for Eileen if you want to know about stroking the slant. The real problem I've seen is the fact we got a tiny bore. On top of which there is no pistons we can really use even if you do sleeve it. The 292 has a 4.125 stroke, but look at the displacment before chevy went there. Bore I think is the down fall in the ratio of cubes - stroke - and bore.
Author:  68barracuda [ Thu May 22, 2008 5:57 am ]
Recieved my second 2 x 2 weber manifold was thinking of what to do with it :?
Then it hit me - locally -RSA - we have had a Valiant Charger - based on the Dodge dart demon we-e-e-el either go turbo with a 4bbl manifold, or weberise this one as well
But I want torque
