| 7 1/4 REAR https://slantsix.org/forum/viewtopic.php?t=2910 |
| Author: | Charlie Schmid [ Tue Nov 27, 2001 11:20 am ] |
| Post subject: | 7 1/4 REAR |
Does anyone have a ring gear carrier bearing adjuster on their bench or in a parts box. I need to know the size of the hex hole in the center, so i know what size nut to weld on a shaft to make a tool to loosen the bearings. I missplaced the tool i had sometime in the last 20 yrs. Charlie flturbo6@aol.com |
| Author: | Doc [ Tue Nov 27, 2001 12:54 pm ] |
| Post subject: | Re: 7 1/4 REAR |
: Does anyone have a ring gear carrier bearing : adjuster on their bench or in a parts box. I : need to know the size of the hex hole in the : center, so i know what size nut to weld on a : shaft to make a tool to loosen the bearings. : I missplaced the tool i had sometime in the : last 20 yrs. : Charlie I have used the end of a A-Body torsion bar, it fits right in. I forget the size so I will check it tonight and let you know. I think the screw adjuster style started in 69, a lot of earlier 7 1/4 had shims to adjust the carrier position. DD |
