timing marks???
https://slantsix.org/forum/viewtopic.php?t=29128
Author:  boredskater [ Sat May 24, 2008 6:08 pm ]
Post subject:  timing marks???
okay, finally grabbed up a timing light.
64 valiant, 225
motors not exactly a show specimen.
where should i be looking for timing marks?
can't locate any obvious marks, maybe buried under gunk. hints on where to start?
Author:  DusterIdiot [ Sat May 24, 2008 6:23 pm ]
Post subject:  Yep...
there will be grooves on the damper/lower pulley, and there should be a tab bolted to the timing cover on the driver's side of the engine with marks on it (10-0-10)... unless your slant is from another 'era' then the timing tab may be on the other side of the engine... start there first...
good luck
-D.idiot
