kick down lever position for a drag car
https://slantsix.org/forum/viewtopic.php?t=29203
Author:  Kidd [ Thu May 29, 2008 7:01 am ]
Post subject:  kick down lever position for a drag car
OK.....so I know I need to wire open the kick down lever for te 904, I have no kick down linkage.....so how far should I wire it open? all the way?
Thanks in advance.
Andrew
Author:  Doc [ Thu May 29, 2008 10:44 am ]
Start with 3/4 open as you test around home. (lever pushed rearward)
Make sure you use strong wire, the pressure in the gearbox gets higher as you rev the engine up, that will want to push the lever forward.
If the trans shifts early and soft, pull the lever back more.
At the track, you will likely try it pulled all the way back, just to see how the WOT shift points act.
Author:  Moparedd [ Tue Jul 08, 2008 12:39 am ]
Post subject:  Re: kick down lever position for a drag car
Thanks in advance.
Andrew
I used a PTO cable with a locking devise so I can push it in on the return road and pull all the way out when racing.
mopar edd
